Knowledge Base
Guides and articles to help you get the most out of the Netlify platform.
Comparison
What makes a good AI app deployment platform? 6 things to check before you commit
Deployment platforms all demo identically, because the demo is one deploy of a simple app. Six properties that decide how the fortieth deploy goes, and the single test that covers half of them.
Reference
AI app hosting explained: what happens after the AI finishes generating your code
A beginner-level account of what hosting actually is, told as the sequence that starts the moment generation stops: what a build is, what a deploy is, where the app physically runs, and what keeps it working afterwards.
Agent Guide
How to run AI agent tasks remotely with Netlify Agent Runners
Delegate coding work to Claude, Codex, or Gemini running on Netlify against your repo. How tasks work, the five ways they differ from a local agent, and how to poll for results.
Tutorial
How to call OpenAI, Claude, or Gemini without API keys
Netlify AI Gateway injects provider credentials into your Functions, so official SDKs work with no config. Setup, the four supported providers, and what it costs.
Agent Guide
How to build and deploy an MCP server on Netlify
A remote MCP server is one Netlify Function speaking the protocol over HTTP. The complete server, bearer auth, rate limiting, and the state trap that only breaks in production.
Reference
Netlify auth: site protection, app login, or team SSO?
Three unrelated things get called auth on Netlify. Which one you need, how to tell them apart, and why their sessions can't be bridged.
Tutorial
How to password-protect a Netlify site or deploy previews
Set project visibility to Password or Private, or use Password Protection on legacy plans. The dashboard paths, the plan gating, and why there's no API for any of it.
Tutorial
How to add user login to a Netlify site with Identity
Netlify Identity handles signup, login, OAuth social login, and role-based access. Setup, the server-side API, and the five footguns including why auth won't work locally.
Tutorial
How to add a Postgres database to a Netlify app
Netlify Database is managed Postgres, built in. Install the package, write a migration, deploy. Includes the Drizzle setup and the migration rules that reject a bad deploy.
Reference
Why your deploy preview can delete Netlify Blobs data
getStore() is site-scoped and shared across every deploy context, so preview code writes to production. Here's the blast radius and the one-line fix.
Tutorial
How to store files and objects with Netlify Blobs
Netlify Blobs is key-value storage for uploads, generated files, and cache-like state. How to use it, which store type to pick, and what belongs in a database instead.
Tutorial
How to resize and optimize images with Netlify Image CDN
Request /.netlify/images with query parameters to resize, crop, and reformat on demand. The parameters, remote-domain allowlisting, and why fm=blurhash renders nothing.
Tutorial
How to handle form submissions on Netlify without a backend
Add data-netlify="true" to a form and Netlify stores submissions, filters spam, and sends notifications. Plus the static skeleton file that framework forms need.
Tutorial
How to run code at the edge with Netlify Edge Functions
Edge Functions run on Deno at the network edge for auth checks, geo redirects, and A/B tests. The handler shape, routing, and why an unrouted function silently never runs.
Tutorial
How to control CDN caching on Netlify
Dynamic responses aren't cached by default. Set Netlify-CDN-Cache-Control to opt in, vary the cache key deliberately, purge by tag, and read Cache-Status to debug.
Reference
How to configure redirects, headers, and env vars in netlify.toml
netlify.toml controls builds, redirects, headers, and environment variables. The rules, the precedence order, and the six footguns that cost people an afternoon.
Reference
How to configure netlify.toml redirects, headers, and env vars
Tutorial
How to add a backend API endpoint with Netlify Functions
Write a Netlify Function in one file, route it where you want, and pick the right execution mode. Includes the limits and the bundling trap that only shows up in production.
Deploy Guide
How to deploy Next.js, Astro, Nuxt, or SvelteKit to Netlify
Build settings and SSR adapters for every major framework, the env-var rules that need a redeploy, and the leftover SPA redirect that silently breaks server rendering.
Deploy Guide
How to deploy a site to Netlify
Four ways to deploy to Netlify, when each one fits, and the deploy-context config that makes it repeatable. Plus the four footguns worth knowing first.
Comparison
TanStack Start vs Next.js
A balanced comparison of TanStack Start and Next.js across architecture, type safety, rendering, data fetching, and ecosystem, plus how each deploys to Netlify.
Agent Guide
Publishing and Updating Live Sites with the Netlify CLI: A Guide for Coding Agents
How a coding agent can use the Netlify CLI to publish a built site or artifact to a live URL non-interactively, capture that URL, and push later revisions to the same address.
Comparison
Netlify vs Render
A fair, technical comparison of Netlify and Render, covering platform architecture, static sites, backend services and databases, cold starts, deploys, pricing, and developer experience.
Comparison
Netlify vs AWS Amplify
A fair, technical comparison of Netlify and AWS Amplify Hosting, covering platform scope, framework support, backend services, pricing models, AWS integration, and developer experience.
Reference
Netlify’s Full-Stack Primitives: A 2026 Platform Map
A reference table mapping the primitives a modern web app needs (compute, data, storage, cache, queues, identity, AI, and more) to the first-party Netlify product that provides each, with third-party options noted.
Reference
Netlify for Coding Agents: Build and Ship a Full App
A reference for AI coding agents building on Netlify: how to publish and update a live site with the CLI, add a database and background jobs, call models through the AI Gateway, and connect the Netlify MCP server, all non-interactively.
Comparison
Netlify Drop vs Vercel Drop
A fair comparison of Netlify Drop and Vercel Drop, two drag-and-drop deploy tools, covering account requirements, build handling, file support, and updates.
Comparison
Netlify Blobs vs Vercel Blob
A fair, technical comparison of Netlify Blobs and Vercel Blob, covering data model, consistency, metadata, size limits, browser uploads, and pricing, with code for both.
Migration
Migrate to Netlify from Vercel
A step-by-step guide to moving a site from Vercel to Netlify, covering build settings, environment variables, redirects, headers, functions, and DNS cutover with zero downtime.
Deploy Guide
Deploy Your v0 App to Netlify
Publish an app you built with v0 (Vercel’s AI app builder) to Netlify, either by syncing to GitHub for continuous deploys or by exporting the code and deploying with the Netlify CLI.
Deploy Guide
Deploy Your Lovable App to Netlify
Publish an app built in Lovable to Netlify through GitHub for continuous deploys, or drag the built files to Netlify Drop, including how to carry over Supabase keys.
Deploy Guide
Deploy Your Google Stitch App to Netlify
Export a UI from Google Stitch and publish it to Netlify by dragging the static HTML into Netlify Drop, with a path to graduate to a Git-connected project.
Deploy Guide
Deploy Your Claude Artifacts or Design to Netlify
Publish a Claude artifact or Claude Design project to Netlify, whether it is a static HTML page you drag into Netlify Drop or a React component you scaffold and build.
Deploy Guide
Deploy Your Bolt App to Netlify
Publish an app you built in Bolt.new to Netlify, either with Bolt’s one-click Netlify integration or by connecting your repository for continuous deploys.
Tutorial
Build a RAG Chatbot on Netlify with AI Gateway and Netlify Database
A step-by-step guide to building a retrieval-augmented chatbot using only Netlify primitives: vector storage in Netlify Database with pgvector, embeddings and chat through the AI Gateway, and no external API keys or vector service to manage.
Tutorial
Background Jobs and Durable Workflows with Netlify Async Workloads
How to run background jobs, event-driven tasks, and multi-step durable workflows on Netlify with Async Workloads, including retryable steps, delays, retries with backoff, and event chaining.
